B402 doc feed
  • MdangerP
    • Sep 2014
    • 45
    [Misc] B402 doc feed
    Does anybody know if there is a way to get to sppd2 in the mx-b402's doc feed without dissembling the entire thing? First machine I have seen sppd2 flag pop out and let me tell you, it was an absolute nightmare. Not to mention the 8 people who came up to me and asked what was wrong with their new machine while I was balls deep in gears. Not fun lol.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: B402 doc feed
    That is a nightmare of a doc feed to repair; things are tightly fit - I've seen a connector slightly askew between the feeder and DF main pwb cause all sorts of errors/jam codes. Check that first.
    • SwisSeV
      • Jan 2016
      • 307
      Re: B402 doc feed
      I was working in that Doc feeder the other day. I would also like to know if there is a good guide for dissembling this catastrophe.
      • ZOOTECH
        • 3375
        Re: B402 doc feed
        You have to go by the service manual until you do it a couple of times then you 'learn' the shortcuts.
        • MdangerP
          • Sep 2014
          • 45
          Re: B402 doc feed
          Yeah I'm in a good habit of using my manuals right away from my time in the air-force. It's just one of those unfortunate situations where the manuals falls short of the massive disassembly required.
          • jp74msj55
            • Oct 2014
            • 149
            Re: B402 doc feed
            They are a pain to take apart and from my experience, you only can break them down so far.
            The whole unit for dealers is $187.98. Part # 0PZ040001796B.
            Some items are just worth replacing unit.
            • SwisSeV
              • Jan 2016
              • 307
              Re: B402 doc feed
              I didn't realize they were so cheap. You're right, it's not really worth putting hours of labor into unfortunately.
              • MdangerP
                • Sep 2014
                • 45
                Re: B402 doc feed
                Luckily because this machine was brand new sharp warrantied the entire doc feed.
