Updating firmware on mx-4070 series
  • Sharptech0892
    • Aug 2011
    • 78
    Ive had smtp and dns settings be cleared after updating.
  • Sharptech0892
    • Aug 2011
    • 78
    Re: Updating firmware on mx-4070 series
    Another one of are tech's reported same thing, after updating scanning no longer worked, guess it's best to do a backup first?
    • MHeon71
      • Oct 2008
      • 489
      I had a similar thing happen on the 3070 firmware. I went from ver 2 to 4. Network folder scanning stopped. When the firmware was at ver 2, I did not have to put the domain as part of the username. After flashing to ver 4, the scanning stopped. The fix for me was to add the domain to the username for authentication.
      • Madnhain
        • Dec 2012
        • 148
        So what I'm hearing here is don't update FW unless I have to until there is a stable release?
        • MHeon71
          • Oct 2008
          • 489
          In my case, I should have had to enter the domain in the username field. Normally, if you are part of a domain you have to. They fixed it on this update.
          • cutdog
            • Jul 2015
            • 5
            Sharp recommends rebooting the machine by the main power switch before the update because something my be running in the background? I always just remove network and fax line, then reboot and load firmware. Never had an issue.
