Sharp mxm 453n
  • dave b
    • Mar 2011
    • 18
    Sharp mxm 453n
    Installed pcl 6 print driver only recognizes top 2 trays in windows it sees all 4 on printer webpage any help thanks dave
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp mxm 453n
    Try printer properties/configuration tab/auto configuration.
    • dave b
      • Mar 2011
      • 18
      Re: Sharp mxm 453n
      Tried it no go
      • spotlifter
        • Mar 2008
        • 65
        Re: Sharp mxm 453n
        Do a full installation by running the 'setup.exe' from the file. I assume you might be installing it by 'Add a Printer' ?
        sigpic
        • faxman28
          • 436
          Re: Sharp mxm 453n
          Originally posted by dave b
          Tried it no go
          you can manually select your printer options in the configuration tab, when auto config doesn't work. if manul config doesn't work, delete and reinstall driver.
