Replace Fusing roller MX-5001N
  • jonathan3205
    • Apr 2016
    • 30
    Hi. Does anyone know the procedure or have the service guide for the disassembly of the fuser unit for the MX-5001N? I need to replace the Fusing roller but the service guide I have does not contain the info on how to replace it.
    Also, if I replace the whole fuser unit, do I need to make some kind of adjustment on the machine or its just plug and play?
    Thanks in advance.
  • nottoosharp
    • 266
    Re: Replace Fusing roller MX-5001N
    If you are handy with a screwdriver and have a Springhawk you can replace that roller without a service manual. Also the fuser is just plug-and-play but you are going to want to reset the maintenance counts for it
    • JLSam
      • Jun 2015
      • 605
      It's plug and play.
      Turn off MFP. Three screws, two in the bottom left and right corner. And one in the Top left corner. And resent Fuser Unit, Fuser Day, and Fuser Web counters in Sim 24-4.
      Good luck!
