Does Secondary Transfer cause Jams on this machine... Whats fix ?
  • Doug James
    • Jan 2012
    • 935
    [Jamming] Does Secondary Transfer cause Jams on this machine... Whats fix ?
    I had a Sharp MX 3100 delivered today and it started jamming just before and into the fuser. The fuser checked out OK but when I checked out the secondary transfer belt on the door to make sure it didn't walk off by turning it on its rollers. I closed the door and it worked fine. I have seen these belts walk off before. Is it the belt or the assembly or is it a common problem..... Any light you can shed would be a great help... Thanks so much !!
  • driving lots of miles
    • Jun 2016
    • 398
    Re: Does Secondary Transfer cause Jams on this machine... Whats fix ?
    Originally posted by Doug James
    I had a machine delivered today and it started jamming just before and into the fuser. The fuser checked out OK but when I checked out the secondary transfer belt on the door to make sure it didn't walk off by turning it on its rollers. I closed the door and it worked fine. I have seen these belts walk off before. Is it the belt or the assembly or is it a common problem..... Any light you can shed would be a great help... Thanks so much !!
    What model machine is this?
    • Doug James
      • Jan 2012
      • 935
      I can't believe I forgot to Put that... Sharp MX 3100
        • Jun 2016
        • 398
        Usually it is the assembly that gets out of alignment and we generally change the whole secondary transfer unit
        • sharptech1
          • Oct 2011
          • 163
          Check gear on back of primary transfer unit
          • lky1978
            • Mar 2009
            • 483
            PRIMARY transfer gear broken
