What would happen if I replace the primary transfer belt only on this model, without doing any stearic acid or strontium titanate treatment? Those are the two the service manual says to use but I don't have either and cannot wait for them to come.
MX-3501n replace primary belt without treatment?
Re: MX-3501n replace primary belt without treatment?
Sent from my iPhone using Tapatalk -
Sent from my iPhone using TapatalkComment
Without proper lubrication the cleaning blade can flip, causing streaks.
I use both powder, or toner*. Never had an issue (except with the Polaris range, powder was causing problems).
* Never use Polaris toner on the transfer belt, as it contains developer. Instead, use an older model's toner.Comment
