Sharp MX M260
  • Tech2002
    • Aug 2008
    • 334
    Sharp MX M260
    When I open the Doc Feed it's showing that the Doc size is 11 x 17. There is no 11 x 17 on the Platen. I'm not sure of the SIMMS to correct the sensor setting to bring it back to 8 1/2 x 11. Any help appreciated.
  • Tech2002
    • Aug 2008
    • 334
    Re: Sharp MX M260
    41-2
    Purpose
    Adjustment
    Function
    (Purpose)
    Used to adjust the detection level of the document size photo sensor.
    Section
    Others
    Item
    Operation
    Operation/procedure
    Place an A3 (or WLT) document on the document table, and press
    [START] key with the OC cover open.
    The adjustment is performed and the result is displayed.
    ใ€€
    OCSW
    Original cover state
    Open: Highlighted display
    Close: Normal display
    1 to 5
    PD sensor detection level (Hexadecimal display)
    The value in [ ] shows the threshold value. (Hexadecimal display) For AB series, 1 to 5 is displayed, for inch series, 1 to 4.
    During execution of the simulation, "EXECUTING" is displayed.
    • bilyahn
      • Dec 2006
      • 1470
      Re: Sharp MX M260
      Before you go to all that trouble, did you clean the two sensors that determine paper size? Might be something as simple as that if you're machine is in a dirty environment.
      Good luck.
      Bil
