Firmware Sharp AR-M450
  • Cooky10
    • Aug 2025
    Please, anybody have (or can get)
    the latest firmware to flash an AR-M450?
  • bilyahn
    • Dec 2006
    • 1470
    This is a 10MB file will your email handle it?
    • vlad_
      • Jul 2008
      • 98
      Ver. M00 firmware will approach?
      • Cooky10
        This
        13
        December, 2002
        mF.01
        m4.02
        • vlad_
          • Jul 2008
          • 98
          Inform the email the address and I will send a file.
          • Cooky10
            salva.linea@gmail.com
            • vlad_
              • Jul 2008
              • 98
              Originally posted by Cooky10
              The file is sent on e-mail.
              • Cooky10
                Perfect
                Thank you all
                • Doreamon
                  Sharp AR-M450 Firmware re-flash
                  My AR-M450N copier cannot boot in to ready state. Can anyone tell me the problem and solution? I suspect is the firmware corrupted, Is there anyway to re-flash the firmware? The boot flash is m4.20C and the main is m1.0
                  • DINGO
                    • 661
                    re
                    Hello
                    please can send me the firmware too??
                    ding-o@sapo.pt
                    thanks a lot
                    • Bacon
                      DOREAMON, do you have a spare M450N or a spare set of chips? If you have a spare set of chips, they do not need to necessarily be M450 chips but they do need to be the same exact type of chips possibly from a machine that had a Data Security kit installed. If you have a spare machine, program the original chips from the down machine using the CN update method using slot CN6. If you do not have a spare machine, but you have a spare set of chips, even if the machine won't boot normally, it may still boot into the rom update mode. Again, use the CN update method to burn each chip individually in slot CN6. It gets a little confusing if you've never done it this way before but with a little patience and trial and error you should be able to figure it out. One quick tip I can give you is that when you use the CN update method, you will upload the rom to the machine first, then scroll through the uploaded roms to select either the boot or the main. This method will work as long as the chips are not already damaged in which case you will get an error upon completion of the programming and you will have to buy a new chip or chips.
                      • silicone22
                        • Akitu
                          Legendary Frost Spec Tech
                          • Oct 2010
                          • 2595
                          Re: Firmware Sharp AR-M450
