MX-5001 N white dots on B/W prints
  • jonathan3205
    • Apr 2016
    • 30
    Hi, I have a problem with a MX-5001N. When printing in B/W there are white spots all over the page. But when printing in color there is no problem. This machine only have 67000 prints on B/W since the last developer change and only started to present this issue since 2 months ago.
    Thank you for your help and advice.
  • lky1978
    • Mar 2009
    • 483
    Re: MX-5001 N white dots on B/W prints
    [ATTACH=CONFIG]34878[/ATTACH]
    toner problem
    • jonathan3205
      • Apr 2016
      • 30
      Originally posted by lky1978
      toner problem
      Problem with the toner unit or the toner brand/type?
      • lky1978
        • Mar 2009
        • 483
        use genuine toner
        • lky1978
          • Mar 2009
          • 483
          make a sky shots and attach here
          • jonathan3205
            • Apr 2016
            • 30
            use genuine toner
            • lky1978
              • Mar 2009
              • 483
              second choice, KATUN
              • jonathan3205
                • Apr 2016
                • 30
                Here is the sky shot
                • nottoosharp
                  • 266
                  [ATTACH=CONFIG]34879[/ATTACH]
                  Looks like DV to me.
                  • jonathan3205
                    • Apr 2016
                    • 30
                    What should I try then? Change the developer or the toner?
                    As a side note recently switched from a brand I do not remeber the name, but was printing fine and then started to use toner BlackStar and it was around that time when the prblems began.
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      BINGO!
                      • nottoosharp
                        • 266
                        So do a DV change. The new toner has a different density.
                        • JLSam
                          • Jun 2015
                          • 605
                          Looks like the developer to me as well.
                          Now If I'm not mistaken i am sure that this model sometimes is missing the upper developer seal, this can cause developer loss but the print defects don't look like spots, but more like diagonal bands.
                          You're doing 25-2 after developer replacement right?
                          • nottoosharp
                            • 266
                            This is most likely a result of switching to a different brand of toner without changing the developer. We found this to be the case and a lot of the black-and-white machine 363's and 283's especially
                            • jonathan3205
                              • Apr 2016
                              • 30
