Question I have is that I have a MX 2640 that is going back to lease return but the HDD needs to be wiped. Not a sharp guy but if you format the HDD do you have to put firmware back in to make it pass paper for leasing company?
MX 2640 HDD
Re: MX 2640 HDD
Sent from my iPhone using Tapatalk -
Re: MX 2640 HDD
depending on your customer and the nature of the data on the hdd, there is a end of lease function that can be accessed through the web page , it does a DOD wipe of the hdd and I think it clears all user areas. A format will not delete all the data on the HDD, there is software available that can pull data off of a formatted HDD.Comment
Re: MX 2640 HDD
Sent from my iPhone using TapatalkComment
Re: MX 2640 HDD
I beg to differ with you that "nobody really ever saves anything sensitive"; when I would set up a lease return for resale, I've found social security numbers, DOB, IRS returns, medical diagnosis, and others - if that info had gotten into nefarious hands, identity theft would have been easy."You can't trust your eyes, if your mind is out of focus" --Comment
Re: MX 2640 HDD
Most of our customers that are worried about it just keep the hdd. I would ask what kind of dipshit saves that stuff to the printer, but we know how customers are.
Re: MX 2640 HDD
Also most new Sharp MFP's have a setting in web page to turn on a simple version of data security to erase copy/print data from hdd, but once it is turned on it can't be turned off.Comment
