Error code Sharp AR 5620 V
  • juventuss
    • Jul 2025
    [Error Code] Error code Sharp AR 5620 V
    I have problem with Sharp Ar 5620 V it make the error code F2 _40
    Please any advice
    what should I do ?
  • bilyahn
    • Dec 2006
    • 1470
    Re: Error code Sharp AR 5620 V
    That is a toner cartridge incompatibility error code so you will need to replace the toner. If you are using non-OEM replace with the correct OEM toner. That should take care of your issue.
    Good luck.
    Bil
