Sharp MX 3100 Noise issue in ADF
  • Doug James
    • Jan 2012
    • 935
    [Misc] Sharp MX 3100 Noise issue in ADF
    This customer bought a MX 3100 machine from me with 200K. It sits right next to her desk and she is not happy about the noise the ADF makes when being used. What can I do to quiet this down. It is also making noise from the fuser like a loose idler wheel. Any help is surely appreciated Thanks so much !!!
  • mttech
    • Mar 2014
    • 127
    Re: Sharp MX 3100 Noise issue in ADF
    For the fuser noise I would look at the cleaning roller first. Can't say on the ADF. Machines make noise when they run. Does it seem to be an unusual sound?
    • Doug James
      • Jan 2012
      • 935
      I've heard the "chainsaw" type noise on all the machines in ADF. Thinking I may quiet it down by changing the feed rollers. The fuser noise I believe is from the cleaning roller. Haven't been back yet. Thanks so much for your feedback. Helps alot
      • CCS
        • 266
        These ADF series are generally just noisy and loud.
        • Doug James
          • Jan 2012
          • 935
          Yep, your right about that... ADF feed tires weren't much help
          • faxman28
            • 436
            check/replace torque limiters, one-way bearing and shaft for lifting/dropping of pick roller. I think there is a belt tightening procedure for gear on adf drive unit for the gear that drives the pick/feed roller unit?
            • ntbann
              • Jan 2012
              • 623
              Take the rear cover off the ADF and there is a feed roller lift belt tensioner. Tightening will eliminate some noise.. Fuser may need to be rebuilt with new bearings and rollers. Bearings rattle over time.
