MX-7040 No Boot or Display
  • xring1958
    • 166
    We have a MX-7040 that wont boot up. No display, no home light the led that is beside the display that tells you when its ok to turn on is blinking and there are fans running. I checked the DC Power supply and Sub DC power supply both are giving me correct voltages but the DC PS had to be tested at other end of connectors since sharp hides the board behind other boards but they seem fine. I guess I will start tracing back from display and se hat goes. If any of you have seen this issue any help is appreciated as always.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX-7040 No Boot or Display
    Check the service manual where it shows the contents of the memories - most likely the SD or CF card will have the 'boot' info, reseat or replace it.
    • JLSam
      • Jun 2015
      • 605
      It could also be the data security kit ROM gone bad.
      I had one MX-5111 with MXfr33u not boot because of the corrupt ROM, and I had to replace perform an emergency firmware update.
      Sent from my ONEPLUS A3000 using Tapatalk
      • kentteam
        • 5
        Perform emergency firmware update
        • kentteam
          • 5
          perform emergency firmware update
          • jp74msj55
            • Oct 2014
            • 151
            SD card most likely problem.
            • xring1958
              • 166
              I have one on order will let yall know if it corrects issue.
              • xring1958
                • 166
                SD Card didn't correct issue have MFP PWB on order
                • harleyrider
                  • Oct 2011
                  • 348
                  they have changed the pwb rom. Be sure and order the right pwb or you may need a rom also. See MFP-TB-785. I ran into this.
                  • xring1958
                    • 166
                    OK everyone thanks for your input. It turns out that replacing the MFP PWB solved the issue.
                    If everyone ends their post with the solution we may add to our recourses for troubleshooting.
                    Thanks Again
