FXX2 fax issues- memory full,job cancel msg on 4101N???
  • CCS
    • 266
    I got this 4101N that all works fine besides the fax, I already swapped another known working FXX2 fax onto it - but still doesn't work.
    When trying to send a fax the machine gives this message:
    "The memory becomes full"
    "The job was cancelled"
    "Wait for the end of communication
    or use another method for resend"
    How do I fix this ? This is the first fax issue ever had with the Sharp MX line
  • JLSam
    • Jun 2015
    • 605
    Re: FXX2 fax issues- memory full,job cancel msg on 4101N???
    Clear fax image data.
    Sim.. 66-10 I think...
    Sent from my ONEPLUS A3000 using Tapatalk
    • driving lots of miles
      • Jun 2016
      • 399
      We have had this issue with two different mx machines and clearing the fax image data worked on both.
      • CCS
        • 266
        I will give that a try, thanks alot.
        • thomfish
          • Jul 2014
          • 101
          Check if memory is installed properly. I had one machine with memory installed in wrong slot!!!
          • repn1999
            • May 2010
            • 310
            Run SIM 66-10 and update mfp firmware. There is a fix in latest firmware to resolve that problem. I have the latest firmware if you need it.
