MX-M623N Hard Drive replacement
  • JayH
    • Jun 2025
    [Misc] MX-M623N Hard Drive replacement
    I'm doing a HDD surrender for a customer. I followed the procedure in the manual and backed up the drive, but I can't get back into simulation mode to restore data. When I power up the machine, it displays: Version Check 1cuM: ROM UNUSUAL.
    How do I get to simulation mode?
    Or-what's the best way to accomplish this HDD replacement? The machine just has to pass paper.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-M623N Hard Drive replacement
    Looks like you lost your firmware. Reflash it with the emergency update procedure and you should be back to good.
    • JLSam
      • Jun 2015
      • 605
      Akitu is correct. However, I should add that you should be mindful on whether the mfp has a DSK installed, if it does, it will need a special firmware designated for that DSK.
      Good luck.
      Sent from my ONEPLUS A3000 using Tapatalk
