MX2610 void streaking on legal only
  • hellcat
    • Jan 2012
    • 126
    Really weird issue going on here. This only happens on the trail edge of legal copies or prints. Can be double sided or single sided. Only on BW not color mode. If you run a BW in color mode it will be fine. Also does not matter what tray you run it out of.
    Things that have been done after problem had occurred.
    Primary Belt/PTC replaced (was at end of life)
    Fuser swapped with a newer one (had like 10K on it)
    Entire Black DV unit and Drum unit replaced with new units
    LSU removed cleaned inspected reinserted
    Checked all milars and free of bends
    fumc_20170125_152806.pdf
    fumc_20170125_152830.pdf
    fumc20170120_182537.pdf
  • mojorolla
    The Wolf
    • 2609
    Re: MX2610 void streaking on legal only
    A few questions if I may:
    -does it exhibit the defect on ledger size?
    -there is a F2-45 error on the 22-6. Can the machine complete SIMs 44-2/6/26 without an error?
    -what does 64-1 pattern 17 look like for black?
    -have you done a panic stop? Run the copy and open the right door before it hits the fuser. Raise the IT belt cam and carefully take it out, is the defect on the belt?
    From your description, something in the black is the culprit.
