Sharp MX5001
  • KMtech69
    • 68
    Sharp MX5001
    I'm working on a MX5001 that copies and prints monochrome just fine but when you copy or print color the machine jams at the registration roller. I did just replace the drums and cleaning blades on the color units. Everything looked fine but customer was out of magenta toner. I went back when they got more toner and found it had this problem.
    Thank you in advance
  • ntbann
    • Jan 2012
    • 628
    Re: Sharp MX5001
    โ€‹Are there any error codes listed in Sim 24? Could be a bad phase sensor.
    • copyguy1
      • Jul 2011
      • 142
      Re: Sharp MX5001
      What is the jam code?
      • ntbann
        • Jan 2012
        • 628
        Re: Sharp MX5001
        Its not a jam code it is an error code (F2-52,53,or 54).
        • Hansen88
          • 1068
          Re: Sharp MX5001
          I have never ran into that code but the manual says problem with the drum drive unit or the drum phase sensor trouble.
          • mojorolla
            The Wolf
            • 2627
            Re: Sharp MX5001
            Those are drum phase errors. You can use SIM 30 to check that the sensors are working.
            These all go to the PCU board, you may have a PCU issue if sensors are not working.
            • spanky
              • Sep 2012
              • 468
              Re: Sharp MX5001
              Do you have a drum unit locking up.
              If you didn't put enough powder on the drum the cleaning blade could be restricting the rotation of the drum
              • tee
                • Aug 2014
                • 79
                Re: Sharp MX5001
                I had 2 of these do this last year , It was a cracked
                primary belt drive gear.
                • boobookitty
                  • Nov 2016
                  • 6
                  Re: Sharp MX5001
                  Without any feedback from OP regarding jam or fault codes, kind of hard to give anymore ideas that aren't pure speculation.
                  • repn1999
                    • May 2010
                    • 310
                    Re: Sharp MX5001
                    I see the pri belt drive gear crack often on these. I actually got in the habit of throwing extra powder on the belts if the machine hasn't been serviced in a while to help with that. I have also seen the ppd2 sensor be flaky on these and it was later updated on the 5111 and models after. I have also seen either the PS unit wear out or the plastic drive collars on the rear of the PS unit strip out in the center. At first it will appear random then happen more often then constant. At Lastly I'd run sim 50-28 setup adjustment and registration on all the trays.
