SHARP MX-7500N Text Appear Smudged
  • obexi8
    • Apr 2016
    • 11
    [Misc] SHARP MX-7500N Text Appear Smudged
    Hello Everyone,
    I am thanking everyone for the help in advance.
    I am having an issue with a SHARP photocopier MX-7500 that seems to smudge text vertically and move on subsequent pages. I have serviced the drum unit and the DV unit which I thought could be the issue.
    Please any suggestions on what to do will help.
  • ntbann
    • Jan 2012
    • 623
    Re: SHARP MX-7500N Text Appear Smudged
    I would check the transfer belt. It looks to me that it is stalling.
    • obexi8
      • Apr 2016
      • 11
      Thats a great suggestion would give it a try on my next visit will service the unit and check if the primary belt is stiff.
      Thanks for your reply.
      • spanky
        • Sep 2012
        • 468
        I have also seen the secondary transfer belt slip on these machines.
        • repn1999
          • May 2010
          • 310
          I would say check the paper stop unit or transfer belt units. I have also seen a black drum unit cause it also once. Hope that helps.
          • spanky
            • Sep 2012
            • 468
            Does this happen on copies and prints?
            If you run it in the single color mode in each of the colors does it still happen.
            This will tell you if it is a problem with the black only or if it is the transfer/second transfer.
            If the fuser drive is slipping you could also get this.
            • obexi8
              • Apr 2016
              • 11
              Hello thanks for the suggestion so I have done the following
              changed the primary transfer with a new one from office machine
              I recently changed the secondary transfer belt
              replaced fuser unit whole from office machine
              cleaned the registration sensor
              its happeneijg on both copy and print and yes when I use the single color mode it's the same problem
              i have also noticed that it does not occur when I print on A3 size
              now I am sensing it might be a registration issue kinda confused tbh
              • obexi8
                • Apr 2016
                • 11
                This is another image
                • obexi8
                  • Apr 2016
                  • 11
                  Another image
                  • boobookitty
                    • Nov 2016
                    • 6
                    You'll have to try a few dead stops to see where it is happening. The fuser suggestion is a good one; the fusers on these are less than spectacular.
                    • obexi8
                      • Apr 2016
                      • 11
                      I will try changing the PS unit next thank you hopefully it's coming from this unit
                      • obexi8
                        • Apr 2016
                        • 11
                        It appears that the problem was the secondary transfer unit (tried with the unit from working machine)..
                        I recently changed the belt so I would have to disassemble this unit to trace what the problem was in the first place.....
                        Thank you for your contributions...................
                        • Jack Reacher
                          • Jul 2008
                          • 26
                          Hi All
                          I am thinking about selling an MX7500 to one of our large print customers and haven't yet dabbled in this end of the Sharp lineup. Could some of you that have had issues with the model let me know what i might be in for. I would normally stop at the 6070 but this customer wants high output.
                          muppet is as muppet does!
                          Jimbob
