MX-565n Wrinkling
  • Cookr
    • Dec 2011
    • 184
    MX-565n Wrinkling
    Working on this Sharp MX-565n and it started to wrinkle the copies/prints has 780,000 on it so I replaced the pressure roller but it still is doing it, customer says it happens on single sided also but I have only had it happen to me with double sided. I cant figured this one out yet and the paper is not wrinkled before the fuser so something is going on there I am pretty sure anyway unless I am missing something. Any Ideas? Thanks
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-565n Wrinkling
    There was a bulletin for the predecessor series regarding adjusting the fuser speed to prevent wrinkling in 11x17 size. Perhaps the issue is similar here?
      so you say the machine isn't wrinkling BEFORE the fuser.. if you pull the paper and open the wrinkle.. there is no toner in it? is there toner build up on the fuser entrance plate? a fin bent or missing on the inlet?
      • fireater
        Repair God? not quite
        • Apr 2006
        • 253
        there are so many mods to the fuser including frame pieces it is recommended you order new fuser
        I fix copiers ...Well Sorta
        • driving lots of miles
          • Jun 2016
          • 403
          I would agree with the toner build up on the fuser entrance plate, I have had several machines do this.
            very common problem on ANY toner based life form
            • Cookr
              • Dec 2011
              • 184
              It was a toner build up issue thanks not sure why I didn't check that the other day. Wasn't a whole lot but enough for the paper to catch on.
                so there was toner inside the wrinkle? that one way to tell it is a fuser issue.. if no toner in wrinkle then it's before the drum area
                • Cookr
                  • Dec 2011
                  • 184
                  Yeah there was toner in the wrinkles but the build up was on the entrance plate I cleaned it up and it was all good and good point
                  • JLSam
                    • Jun 2015
                    • 605
                    That was hilarious! I just want you to know that someone, somewhere out there in an Indie Dealership. Someone printed this comment and put it in a plaque for the occasional giggle.
                      well to me they have always "toner based life forms" because sometimes they have a mind of their own!
                      and kinda like a person on government ASSistance ... they 'work' when it pleases THEM.
                      • repn1999
                        • May 2010
                        • 310
                        Do this modification. I know this says for MXM354 and the small machines But the lower cover and mod parts are the same. Idk why Sharp didnt put this in the MXM565 area but we have done it several times and it has fixed the wrinkling issue. ALSO when ordering new fusers you MAY or MAY NOT get this mod. It's random. Buying the mod parts are cheaper than a fuser. You need the lower cover, 4 mounts and 4 start rings. USA models only require two mounts per side, A4 models 1 per side in the center.
