Sharp MX-3640
  • driving lots of miles
    • Jun 2016
    • 399
    Sharp MX-3640
    We picked up a used 3640 that is leaving a 1/2 inch off color line on copies both B/W and color (see attachment)
    Internal prints are good. Firmware is up to date.
    we have tried new transfer belt, the off color line is appearing on the belt which leads me to think drums, but we tried a complete set of new drum units and no change.
    I have cleaned the laser slits and also all the optics on the scanner and new charge units were in the drum units.
    There are 49,600 copies on the machine.
    [ATTACH]35723[ATTACH]
  • outdoorkatie123
    • Feb 2017
    • 50
    Re: Sharp MX-3640
    Hi I would check the optics again every thing seems to point to them. Give the lamp a good clean with solvent cleaner.Ive had something similar before and cleaning the lamp cured the problem
    • copyguy1
      • Jul 2011
      • 142
      Re: Sharp MX-3640
      Since internal prints look good It would be a optical problem, Try scanning to PC or do a preview and see if it showa up there.
        • Jun 2016
        • 399
        Re: Sharp MX-3640
        Just tried that, but unfortunately that did not help. thanks for the reply
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: Sharp MX-3640
          print a 64-1. this will show which color is faded in that area. if it's not the laser glass it's likely some debris on the mag roller of the dev unit
            • Jun 2016
            • 399
            solution for problem
            I cleaned the mirrors with alcohol and that moved the mark on the page so I really scrubbed the mirrors with alcohol and that took care of my problem.
            Thanks for everybodys help.
            • repn1999
              • May 2010
              • 310
              Re: solution for problem
              Another common issue is toner dropping onto the laser lens and will cause a void or discolored line in some cases. Its easy to check before changing parts out and fixes about 50 percent of the issues we see. YMMV
              • harps05
                Field Service Engineer
                • Mar 2012
                • 112
                Re: Sharp MX-3640
                I'm going with a dev blockage also.
