DIYer looking for help
+ More Options
Posts
  • Jorabi
    • Jul 2011
    • 19
    Is there an online forum more appropriate for non-professionals to get troubleshooting help? I have an MX-3501N in my home which was given to me by the local library. It has been working fine for a year but now it isn't. I cannot afford professional service calls, but I am mechanically/electrically inclined and am hoping to find the problem myself with a little guidance. Thank you.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: DIYer looking for help
    [QUOTE=Jorabi;553151]...but now it isn't.
    If you give us symptoms, we might just be able to help. Up to a point, with your understanding that you might make matters worst.
    • Jorabi
      • Jul 2011
      • 19
      Zootech thank you for your offer to help.
      Since moving the machine, I can no longer print from a PC without it jamming immediately. If I make copies, it does not jam. The jam happens without ever delivering the first print. There are always three sheets to be cleared from the pull-out section on the right.
      I am attaching pertinent photos. One of the photos shows a part that appeared in the area at some point after the move. I don't know if it's related.
      EDIT: forgot to mention the jam occurs regardless of which paper tray I use.
      • ZOOTECH
        • 3375
        [ATTACH=CONFIG]35750[/ATTACH][ATTACH=CONFIG]35751[/ATTACH][ATTACH=CONFIG]35752[/ATTACH][ATTACH=CONFIG]35753[/ATTACH][ATTACH=CONFIG]35754[/ATTACH]
        That part is a separation pawl from the fuser unit (located on upper right side). Your firmware is out of date - the ICU main should be at 2a11.J0.
        If it is not jamming when copying, than you print driver configuration, and or settings may be off.
        • Jorabi
          • Jul 2011
          • 19
          Is that pawl critical or can I run without it?
          Is there a way for unauthorized persons to obtain updated firmware?
          • ZOOTECH
            • 3375
            It is apparently running in copy mode without that part. You could try a goggle search for the firmware.
            It printed fine for a year, is that correct? Have you gotten a new PC and reloaded the print driver?
            If so, than you may need to set the tray settings in the configuration tab of your Printer Properties.
            If the IP port shows it is a WSD port, that can cause problems; also, the port configuration should be LPR with a queue name of lp (lower case).
            • Jorabi
              • Jul 2011
              • 19
              Yes, it worked for a year. I have new information. It jams while COPYING as well as printing, but only when the output is 2-sided. So it is not a PC or driver config issue. Copying and printing both work fine if single sided.
              The jam happens immediately and one blank sheet has to be cleared from the top right side of machine, inside the pull-out section.
              • ZOOTECH
                • 3375
                Check the right-side pull out drawer; maybe a myler sheet, or rib with paper cuts. The duplex motor might be a problem; run simulations to test motors. You may also disable jam with Sim 7, and see if it still jams. If it does not, you have a sensor problem.
                • repn1999
                  • May 2010
                  • 310
                  Hi. I am pretty sure I know your problem. These machines have a really bad know issue with the duplex guide and gate on the upper right door warping. Sharp made a modified guide and added little clear fingers to it to help as well. That's basically how you can tell. This is a common issue. The easiest way to check is to look at the flat edge on the bottom of the black guide. It it should be straight and even. If it's not replace it. I can give you the part numbers. The second common issue on these is they like to strip out primary transfer belt drive gears. Usually because the belt cleaning blade becomes dry. The picture you posted is of a fuser lower picker finger. You really need these. Without them paper will catch the top gate on the fuser and jam. When these get knocked off its common to tear up the fuser requiring a replacement fuser or a rebuild. The rebuild kits are expensive and a new fuser is about 500 bucks. I happen to have one I can sell if you need it. Let me know. Btw I've worked on these since they were new and went to sharp school on them. I've spent a lot of time on them so I can pretty much fix anything on them.
                  • repn1999
                    • May 2010
                    • 310
                    I have added the bulletin showing the issue below. It also lists the new parts needed.
                    • Jorabi
                      • Jul 2011
                      • 19
                      Going by your bulletin, I have the old Reverse PG and no lower PG pawls.
                      I am looking at the bottom of the reverse PG and it looks straight, using the steel below it as a guide. Here is a picture.
                      Should I replace the PG and add the new pawls as the bulletin says, or wait until I confirm there are no other problems, using simulations?
                      Thank you. The service manual calls it "Lower separation pawl" as Zootech mentioned. There was a hole where the 4th one belonged, so I installed the loose one there. That wouldn't be causing my POD1_S and APPD1_N jams, would it?
                      • ntbann
                        • Jan 2012
                        • 626
                        This could be a sign that the exit unit is going bad.
                        • repn1999
                          • May 2010
                          • 310
                          Your picture is from facing the guide. Look at it looking at the flat bottom side and look to see if the back edge that faces the door when it is attached is straight. It warps in the center and bows out. Could be a delivery unit but I'd check the guide first.
                          • fireater
                            Repair God? not quite
                            • Apr 2006
                            • 253
                            I wouldnt worry about firmware ... the little duplex gate on the side door that flips up as you close it gets stiff in the bushing .. clean bushings with alcohol.. leave dry do not lube.
                            the pawl in the fuser should be replaced. also check for gouges in the rollers from the pawl. the rollers need to be good.
                            I fix copiers ...Well Sorta
                            • Jorabi
                              • Jul 2011
                              • 19
                              Should the flip-up gate with all the fingers, snap all the way closed (down) when I raise it with my hand and let go? It is only goes down about half way on its own, as if the spring on the left end of the rod is not tight enough.
