MX-6070N with MX-FN28 - FNRMDLT
+ More Options
Posts
  • coopers1305
    • Nov 2014
    • 49
    [Jamming] MX-6070N with MX-FN28 - FNRMDLT
    Hi Guys,
    Since I first installed this machine it has been jamming between the finisher & the MX-RB25. At first with all sizes of paper & so because their were no bulletins on Sharp IDNC at the time I made up my own fix by putting mylar on the finisher entrance. That worked for a long time but now & only with paper longer than letter size is jamming. With a code of FNRMDLT.
    Most recently, I've tried changing the springs on the sensors in the MX-RB25 to no avail.
    From the time I worked on this last time, I kind of remember seeing a bulletin on slowing the paper down due to bending of the sheets leaving the pass unit but now I can't find it.
    Thanks guys
  • RascalMJ
    • Mar 2009
    • 174
    Re: MX-6070N with MX-FN28 - FNRMDLT
    Perhaps this?
    MFP-TB-1646
    "Guide sheet has been added to the open/close paper guide section to improve thedelivery performance of the paper curled upward"
    Originally posted by coopers1305
    Hi Guys,
    Thanks guys
    • Hansen88
      • 1079
      Is the finnisher height set right so the finnisher entrance guide matchesthe exit of the rb unit?
      • Ditchman
        • Feb 2011
        • 51
        Has anyone got this bulletin? Doesn't seem to be available on UK site
        Originally posted by RascalMJ
        Perhaps this?
        MFP-TB-1646
        • driving lots of miles
          • Jun 2016
          • 401
          we had this issue with MX-4570N with MX-FN28 and the entrance guide on the finisher was bent on delivery of the machine to the customer. They were in the midst of a remodel and they moved the machine twice more and the tech had to go out and realign the guide every time.
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Have the foam rollers been removed from the exit/delivery unit during set up ?
            It didn't say that I couldn't do it in the manual.
