Sharp MX-FNX9 Finisher Installed on a MX-4101 Color
  • Tech2002
    • Aug 2008
    • 334
    I've got an error code FPDD_S relates to a Punch Unit with Finisher. There is no Punch Unit. The Stalls occur when the last sheet of paper exits into the receiving tray or, more often, stalls occur just before Bundle Exit Paper Transport Roller. The unfortunate is that this occurs intermittently, making it difficult to trouble shoot. Tried changing the Paper Exit Sensor with no luck. Machine is very sound and has been working fine up to this point. I am certain that it is the finisher and not the machine.
    Anyone see this happen before? Any suggestions would be greatly appreciated.
  • xring1958
    • 166
    Re: Sharp MX-FNX9 Finisher Installed on a MX-4101 Color
    FSTPD.JPGThe manual shows this is the sensor that is causing the code
    • Tech2002
      • Aug 2008
      • 334
      Originally posted by xring1958
      [ATTACH=CONFIG]35887[/ATTACH]The manual shows this is the sensor that is causing the code
      Thank you. I'll try changing the sensor. I'm not sure how I missed that according to the code that was coming up for me.
      • Tech2002
        • Aug 2008
        • 334
        I changed out three sensors with no luck. I could never see any arm sticking but re-cleaned and used a special spray, checked the system again - it worked fine. Go Figure.
        I appreciated the input.
        • teklife256
          • Sep 2012
          • 164
          Was this issue resolved for good?
          Have a similar situation with sensors on order
