F2-72 F2-73 on MX3060
  • boutn
    • Jun 2016
    • 540
    Hello,
    We are getting some F2-72 and F2-73 errors on the mx3060/5070 series machines.
    Anyone else has this problem?
    Original Sharp toners are used.
    All of the sudden, they are giving these codes...
  • dwarf
    • Oct 2012
    • 168
    Re: F2-72 F2-73 on MX3060
    we've seen an increase in defective OEM toner from Sharp...works for a while then suddenly kicks a code...no rhyme or reason...
    • fireater
      Repair God? not quite
      • Apr 2006
      • 253
      these are coming with the dev in from factory .. during setup are you running 25-2? if so DONT!!
      this is advice direct from Sharp
      Also were the toners well shaken?
      I fix copiers ...Well Sorta
      • xring1958
        • 166
        Look closely at the openings in the developer units & make sure the clear seals have been removed. This happened to us.
        I don't think re running 25-02 with no toner ever added would cause an issue it would just repeat a step.
