L8-03 abnormal input voltage error
  • dwarf
    • Oct 2012
    • 168
    [Electrical] L8-03 abnormal input voltage error
    has anyone ever seen this code appear on a MX-M5070 ?
  • jp74msj55
    • Oct 2014
    • 149
    Re: L8-03 abnormal input voltage error
    This is what manual states.
    Trouble detection PCU
    Cause Detects abnormal input voltage
    Check & Remedy Check the connection of the AC monitor PWB,
    harness, connector.
    Check the PCU PWB and replace if necessary. Good luck, haven't seen this one.
    • Ftrjetf16
      check the ac wire going from the ac power supply to the ac monitor pwb i had one come loose and it was rubbing against one of the dv motors on the bottom right of the machine on the back and was arcing. you could see the burn marks on the motor
