Sharp MX-3100N
  • victorbb1
    • Apr 2017
    • 1
    [Error Code] Sharp MX-3100N
    replaced fuser because of error code L4-16 need help fault will not clear
  • Iowatech
    Not a service manager
    • 3930
    Re: Sharp MX-3100N
    Actually it would be best if you posted about that here:
    http://www.copytechnet.com/forums/sharp/
    That's where most of the techs with experience with Sharp equipment can be found.
    I'd try to help with that problem, but I only worked on analog Sharp equipment, and actually only the smaller stuff too. So I'm not going to be terribly helpful.
    Still, good luck!
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: Sharp MX-3100N
      Thank you for being a 'contributor', do a "Google" search on this site - you'll find the answer to clearing your code?
      • harleyrider
        • Oct 2011
        • 348
        Re: Sharp MX-3100N
        probably HLPCD sensor bad.
