MX-x070n series Pages folding over in center exit
  • oeshuron
    • May 2008
    • 259
    Found bulletin. Can be deleted.
  • oeshuron
    • May 2008
    • 259
    Re: MX-x070n series Pages folding over in center exit
    Correction. Bulletin did not solve issue. Pages are still hitting clear center tray and folding under and back towards machine exit causing them to pile up.
    • JParker
      Technician II
      • Jul 2015
      • 51
      Sorry, I didn't see your original post. The pages are folding or are they curling? Is it on simplex or duplex..or both?
      • oeshuron
        • May 2008
        • 259
        Simplex/Duplex both. Pages come down out of exit, hit the clear tray, and instead of going up the tray and laying down they curl underneath back towards the machine. Its almost as if the angle at which the pages come of out the exit is too steep before it hits the clear tray. Removing the full detect arm does help some but doesn't solve the issue completely.
        • driving lots of miles
          • Jun 2016
          • 393
          Have you tried a new package of paper to rule out Humidity?
          • JParker
            Technician II
            • Jul 2015
            • 51
            Have you looked at your fusing assy? You can use SIM 43-1 to try and adjust the curl if its caused by fusing temperature. Unless you've already done that. There's also SIM 43-35 for a nip check!
            • oeshuron
              • May 2008
              • 259
              Two different brands.
              • oeshuron
                • May 2008
                • 259
                Will be the next thing to try once we get the exit unit back in.
                • spanky
                  • Sep 2012
                  • 468
                  See attached bulletin for static issue at exit of machine.
                  • oeshuron
                    • May 2008
                    • 259
                    The earth harness was already there. We reset all fuser settings (didn't see any changed) in 43-1 and did nip check (ok). Also changed paper mode in settings to 23-28lb. Seems to be better. Will continue testing.
                    • kev577
                      • May 2016
                      • 12
                      Have the foam rollers on exit assembly been removed? They should be on if there is not a finisher, remove when installing a finisher.
                      • oeshuron
                        • May 2008
                        • 259
                        The top set of rollers had been removed but installing them didn't help.
                        • Ben Around
                          • Apr 2012
                          • 151
                          I had this happen once on a Ricoh machine. The tray was set to thick paper and it went unnoticed.
                          • oeshuron
                            • May 2008
                            • 259
                            Machine had latest firmware installed, hdd formatted, and system settings reset.
