MX-4141 ghosting
  • campy
    • May 2012
    • 315
    MX-4141 ghosting
    I am having a ghosting problem and it seems to be with the variations of blue color. I ran the cleaning wands on the cyan drum and laser and that didn't seem to help. I am mostly a Canon guy and this is my only Sharp color so I am unfamiliar with the everyday type problems and don't want to randomly do things without knowing what to do first. They are printing their letterhead on 20lb paper and the logo is repeating a faint image about the diameter of the drum. The color drums only has 59K and I think they are good for well over 100k. The logo is the only part repeating, nothing else. I had this problem with the black drum, but that had a very large area repeating in the middle. Is it possibly the cyan drum?
  • Jhonjon
    • Sep 2013
    • 208
    Re: MX-4141 ghosting
    If you have a doubt in Cyan Drum try to exchange the drum unit to other color. 59K copies only but it is possible also that the age of the drum.
    • campy
      • May 2012
      • 315
      Thanks, I totally forgot they are all the same, Canon are all different. I feel so stupid.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        If you do a SIM 64-1, pattern 17, and select C. What does the output look like? If it looks good, try immediately after that printing the same pattern but with the dots set from 255 to 1, to print a blank page. Also, try printing SIM 64-5 pattern 1, multiple times.
        If you get ghosting it could be either fault cleaning blade, or fuser belt.
        The blade comes with the charge kit and is cheap and easy to fit; but if you don't have one you can try just cleaning the blade's edge, and resetting with some yellow toner.
        If the fuser belt is ghosting you can usually tell how worn it is by its colour. The belt should be a glossy darkish brown colour, if it looks matted and orange it is worn. If it is showing signs of toner build up on the edges, it should be replaced ASAP.
        • campy
          • May 2012
          • 315
          Went back yesterday and the problem wasn't nearly as bad. Swapped the black drum with cyan and the problem went away. Ended up cleaning drum blade and that seemed to have cleared it. I think it may have been environmental more than anything for some reason as it seems it was going away on it's own. Perhaps moisture, it's been wet here.
          • driving lots of miles
            • Jun 2016
            • 397
            We have several of these under contract and cleaning the blade is usually only a temporary fix. You need to go ahead and change the Drum and the charge kit which has the drum blade included.
            • campy
              • May 2012
              • 315
              The drum only has 59K on it.
                • Jun 2016
                • 397
                With most of our units an hour or more a way it is cheaper for us to go ahead and replace the parts than have a call back in two or three weeks when the problem comes back
                • repn1999
                  • May 2010
                  • 310
                  Doesnt matter what the drum count has one it. The powder wears off the blade over time causing it to then wear and then cause streaking. Can happen on any color. I saw it most on black. I replace the drum and mk kit as a set to resolve. works every time.
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Agree, and the way the copier is used (one or two at a time, or multiple sets) can have a drastic affect on copy/print quality and life of supplies.
                    • Tech2002
                      • Aug 2008
                      • 334
                      Agreed. Had same issue. Changed Drum and fixed issue. Started out thinking it was the clients software - not.
