MX-5111N screen background setting...
  • ChrisLee
    • Mar 2017
    • 7
    Cannot find a way to revert this 5111N's screen back to factory default. As it is, there is an organization's logo and motto behind the usual buttons. I found what looked like the answer in system settings/operation settings. Here I was able to change the color of the buttons. But nothing to replace or delete the company branding, which spans the entire screen. Any ideas out there?
  • ZOOTECH
    Senior member of CRS
    • 3376
    Re: MX-5111N screen background setting...
    Log in as admin to the web page -
    you'll find settings there that can delete current screen and return it to default.
    Sorry, I have forgotten the actual tabs to access those settings.
    • ChrisLee
      • Mar 2017
      • 7
      Thanks, but I simply cannot find that particular setting. Operation Settings has "MFP Display Pattern Setting" which is the closest I can find to it. That setting does change the color of some display elements, but that's it. The logo and motto remains. Odd. I'm beginning to think it was written to the firmware for this company, but that doesn't really make sense.
      • faxman28
        • 435
        go to operation settings home screen settings background image. can only be set via web page
        • ChrisLee
          • Mar 2017
          • 7
          The Home Screen settings doesn't include a background image setting. It should, of course. And it makes me wonder if a customized firmware was applied to this 5111N. Here is a screen shot.operation-settings.JPG
          • ChrisLee
            • Mar 2017
            • 7
            Here is the 5111N's screen:
            • ZOOTECH
              • 3376
              The Home Screen settings doesn't include a background image setting. It should, of course. And it makes me wonder if a customized firmware was applied to this 5111N. Here is a screen shot.[ATTACH=CONFIG]36724[/ATTACH]
              You're close, but it's not on this screen shot.
              • ChrisLee
                • Mar 2017
                • 7
                Logically it should be close. Unfortunately, the operation settings page ends soon after, without a background setting. Weird.
                • spanky
                  • Sep 2012
                  • 468
                  On web page
                  system settings
                  operation settings
                  tab at top of page for image, click on it
                  set image to default
                  You must be signed in as administrator on the web page
                  • ChrisLee
                    • Mar 2017
                    • 7
                    Got it, finally. Don't know why I wasn't seeing that tab. Thanks for your help.
