sharp mx-m283n system setting disables prints from incoming faxs
  • VBS Tech
    • Nov 2016
    • 12
    I have a customer over 100 miles away and they have a sharp mx-m283 that has a message on the screen" system settings disables prints from incoming fax". i had the customer preform a sim 66-10 (fax image clear) and the message went away, i had him send my office a test fax which we recieved but moments later he called back saying the message reappeared. I havent heard of this message before any help would be appreciated.
  • copyguy1
    • Jul 2011
    • 142
    Re: sharp mx-m283n system setting disables prints from incoming faxs
    check under paper tray settings to see if at least one tray is enabled for faxes.
    • lky1978
      • Mar 2009
      • 483
      A PIECE OF CAKE
      • VBS Tech
        • Nov 2016
        • 12
        thanks for the info, it was a tray setting. Without informing us they swapped 2 machines around and for some reason the newer machine had ledger in tray 1 and letter in tray 2 and the fax was set as tray 1 so it was a very easy fix, thanks.
