sharp mx-fnx9
  • clark
    • Sep 2016
    • 109
    sharp mx-fnx9
    Looking for the main board for this finisher. My finisher is dead. Thanks
  • lky1978
    • Mar 2009
    • 483
    Re: sharp mx-fnx9
    the main board not easy to dead. Can explain your finisher problem?
    • clark
      • Sep 2016
      • 109
      Re: sharp mx-fnx9
      I just a code F1-00 saying that the finisher communication error. When the machine turns on nothing from the finisher just a code. thanks for any help.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: sharp mx-fnx9
        With the power off, disconnect the finisher plug from the machine; push on the machine side connector, and see if it is locked in place. If not, the finisher plug seems to connect, but it may not be totally seated.
        • clark
          • Sep 2016
          • 109
          Re: sharp mx-fnx9
          Thanks. I tried that and on 2 different machines. Checked the fuse on board on the finisher and it checked out good. Thanks
          • spanky
            • Sep 2012
            • 468
            Re: sharp mx-fnx9
            I have had this before and the issue was the actuator and sensor for the upper tray home position.
            If you move the sensor so it is triggered just a little better by the actuator this will correct your problem, or the actuator could be broken.
            • mttech
              • Mar 2014
              • 127
              Re: sharp mx-fnx9
              I have seen a broken wire in the interface harness from the copier to the finisher. I suggest to check your continuity for the harness wires.
              • techwurk
                • 127
                Re: sharp mx-fnx9
                Like Zootech said, with power off and machine unplugged check the connector at the copier side, remove the back cover to be positive you have a full connection. The frame there is very thin and easily
                bent. I had this before with that f1-00 and that was the reason.
                When I started servicing copiers they used toaster ovens for fusers.....I'm old
