sharp mx-m264 nv stucked
  • yasinzaeem
    • Jan 2017
    • 8
    hello,
    I have sharp mx-m264 nv problem, when i power switch on, the machine, machine graphic display is stop/stucked, i try to many times to switch off/on , but the problem is still there. is there any solution to help me out.
    thank you
  • MHeon71
    • Oct 2008
    • 489
    Re: sharp mx-m264 nv stucked
    Stopped where? Twirling stars, "Please Wait" message. It may be your SD card. If you have another machine, you can swap out to test.
    • repn1999
      • May 2010
      • 310
      replace the sd card. dont swap from another machine....it caries serial info on it and you can corrupt the card from the second machine and cause 2 down machines if you swap.
      • ntbann
        • Jan 2012
        • 631
        I just copied a good SD card from a working machine to a new cheap sandisk SD card and it worked fine. Addresses and network settings are copied to new card but that's easy to change once the machine is back up. Don't know why sharp thought it was a good idea to use a SD card as a hard drive. Even after they changed the card 3 times in manufacturing they still fail!
        • repn1999
          • May 2010
          • 310
          I made images of all the replacement sd cards from sharp and do that now on all my machines. Sharp used sd because they're cheap and to eliminate mechanical failure. They never considered read write endurance of the cards they purchased.
          • gregoryrbrts
            • Mar 2017
            • 33
            Originally posted by yasinzaeem
            hello,
            thank you
            The problem is your SD card, according to the service manual you are supposed to back up the data but don't because then you will backing up corrupted data. Once you replace it the machine should come right back up. Make sure when you order the card to make sure if it has a hard drive or not because there is a difference in the SD card because it is preloaded with firmware. Also make sure that you reflash the firmwarer after the card is installed.
            • Tech2002
              • Aug 2008
              • 334
              I have had issues with SD Cards on the MXM264, having the black screen. One time, before actually replacing the card with another I had an epiphany. Don't know what caused me to try this, but I took back of machine off, got to the SD Card, with the machine off, Pulled SD Card out, turned on the machine, turned off machine, inserted SD Card, turned machine back on, and everything worked fine. It only took a few hundred dollars to figure this out.
              My issue was the Plug Power Outlet - not good a lot of Browns and this machine does not like Browns. Shut-off and Sleep Modes need to be Staggered or you can have SD Card issues. But if you have continued issues, it probably is NOT the Copier but the electrical outlet. Steady Power with the New Sharp Copier Line is very important. Hope this is a help.
              Another issue I actually caused was when I accidently shut machine off while I was exiting SIMMS. It screwed up the SD Card in a MXM365, so much so, I had to replace the Card at my cost.
              • yasinzaeem
                • Jan 2017
                • 8
                thanks for your post please tell me how to copy the sdcard, i have 2 Sharp MX-M264NV machines 1 machine sd card is not working, mashine is stucked on startup when the stars twirilling, i take the SD CARD from other machine, put the stucked machine, and start it, machine is working perfectly, after that i try to SD card but whenever i put the SD card in Card Reader and connect with the computer, the message is appeared, "FORMAT THE SD CARD"
                PLEASE HELP ME HOW I COPY THE CARD.
                THANKS
                WAITING FOR REPLY
                zAEEM
                • mojorolla
                  The Wolf
                  • 2630
                  You can use this free program to read/write SD and mSATA cards....
                  HDDRawCopy1.02Portable
                  • yasinzaeem
                    • Jan 2017
                    • 8
                    Hello dear,
                    thank you very much i copied the card, i have another problem. i changed the network setting, but the SCANNER 'ADDRESS BOOK' i can't delete it, please help me how i delete the old ADDRESS BOOK, and also pls help me how i REFLASH THE MACHINE.
                    THANK YOU VERY MUCH
                    • Bu abdulla
                      • Apr 2022
                      • 1
                      I try to copy the sd card with HDDRaw it finish copying but still not working the orginal that work portion is unlocated
