sharp mx m453n
  • dcooper
    • Nov 2014
    • 37
    [Misc] sharp mx m453n
    I have a mx m453n copier that intermittently after going into energy save mode (sleep), does not come out of this mode.
    It's supposed to come out of sleep mode if you print to it or if you press the green energy save button. I was wondering if anyone knew
    what would cause this not to come out of sleep mode. Sometimes after a while all of a sudden it starts working and you can't get it to fail.
    Thanks for your help.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sharp mx m453n
    I've read here on forums to set 'Power Off' and 'Power Save' to different values.
    • techwurk
      • 127
      Re: sharp mx m453n
      Also check your settings via the web page
      When I started servicing copiers they used toaster ovens for fusers.....I'm old
      • dwarf
        • Oct 2012
        • 168
        Re: sharp mx m453n
        we had this problem once but I can't remember the model...we had to replace the MFP board...
