Very Sporadic pinging
Re: Very Sporadic pinging
Hi A few years ago we had problem almost the same mx-2614n machines with Cisco switches.It seems the network chipset of that model has a problem with Cisco switches that can sometimes cause that fault. Sharp could not give us a solution that worked.We ended up changing to mx-3050 printers I am sorry that proberly does not help but maybe help with the fault but where to look for a solution.Comment
Try setting the NIC rate to simplex instead of duplex and manually set the speed, even if it is picking up a gig circuit. Check the structured cabling as well that they are not using copper clad aluminium cables too, as they fail frequently and are known points of failureComment
