FXX-2 Memory part number?
+ More Options
Posts
  • guitar9199
    • Sep 2016
    • 1100
    Hey troops, I'm in the midst of refurbing a Sharp MX-M503, and the boss wants a fax on it as well. I have a spare FXX2 fax unit here, but there's no memory chip.
    Can someone let me know the part number so I can order one?
    Thanks in advance...
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: FXX-2 Memory part number?
    I believe it's the same as the older FX models > AR-MM9.
    • techwurk
      • 127
      I believe the FXX3 chips are the same as well if you have one laying around
      When I started servicing copiers they used toaster ovens for fusers.....I'm old
      • ZOOTECH
        • 3375
        As I somewhat remember, there were one or two fax kits that do not have standard memory.
        • techwurk
          • 127
          I checked and they are the same as FXX3, the only number on the chip is (4-N1485FC) which is a common flash LV PWB used in Sharps but the one you want will also have stamped "G 3" in the white block area next to the number. Not sure if they can be ordered separate from the module though
          • spanky
            • Sep 2012
            • 468
            CPWBN1485FCG3
            Cost is around $50
            • lky1978
              • Mar 2009
              • 483
              u can use an old sharp arm450 350 printer controller board, take out MAIN ROM or BOOT rom. They are same.
              remember after install the memory rom, clear cache with sim 66-10
