Sharp xx70's and Airprint
+ More Options
Posts
  • mansart
    • 852
    Can anyone tell me if the 70 series needs to be set up as a wireless device in order to Airprint?
    Or can the machine be wired and Airprint as long as the wired network and wireless are the same?
    TIA
  • boutn
    • Jun 2016
    • 540
    Re: Sharp xx70's and Airprint
    TIA
    According to me, all the Phoenix Griffin machines are airprint enabled...
    The machine can be on the wired network as long as your wireless is the same IP-range.
    If you set the wireless access point on the machine, you have to connect to it, and you have no internet connection while you're connected...
    • MattL
      • Apr 2012
      • 97
      Just enable it on the machine and restart and it should be fine. Note some wireless networks may need mDNS enabling on the wireless SSID that is been pushed out but not had to do it for a while though.
