My customer's MX-4111N will NOT print or copy pamphlets. It will let you choose "Pamphlet" but outputs to the top tray without folding or stapling. Very Curious! Normally when you choose "Pamphlet" the image of copier in the display will highlight the lower output tray green, indicating it has entered pamphlet/saddle stitch mode. This machine highlights the upper/normal output tray - and that's where the copies/prints go, unfolded/unstapled. Reflashed the copier, the finisher, and swapped out the Controller Board in the finisher ('cause I have extra MX-FN10's) to no avail. Ready to get out the hammer. Help!
MX-4111N won't Saddle Stitch
Re: MX-4111N won't Saddle Stitch
you might want to use a 9mm hollow point copper jacketed bullet.. smaller hole just as much damage to the copy engine... may I suggest execution style? two to the back of the machine -
Are you copying or printing? I found a similar problem on our 5111, we were copying and it gave same result as you, the problem was the way we ran the paper, we had to put the paper in the drawer in the (r) position. that would be 8 1\2 inches front to rear and 11 inches right to left. and had to load originals in doc feeder the same way then it folded and stapled for us. I hope this helps.Comment
For printing:
The copier has two pamphlet modes, one with fold and staple, and one without.
To make a stapled pamphlet, you need to select 2 centre staples, as well as pamphlet mode.
For copying:
Most likely the "Automatic Saddle Stitch" function has been disabled, if so, you can turn it back on in System Settings > Device Control. Without it, the user has to select pamphlet copy, then select saddle stitch (under Others).Comment
For printing:
For copying:
Also check sim 22-10 to see what type of finisher the 4111n has connected, the other item in the user guide mentions that 2-sided mode has to be working(see below). also check the saddle stich stapler in sim mode, either the copier doesn't know it has a saddle stich finisher or the stapler or duplex has issues.
To staple copies automatically when Pamphlet Copy is enabled:
From the "Setting mode", select [System Settings] → [Copy Settings] → [Copy Setting] → [Automatic Saddle Stitch].
This is used to activate Saddle Stitch automatically when Pamphlet Copy is enabled when a saddle finisher is installed. To make pamphlet copies without stapling when the [Automatic Saddle Stitch] option is ON, tap the [Staple Sort] key. Then, select [Pamphlet Copy] and tap the [OFF] key on the saddle stitch screen
When Pamphlet Copy is selected, 2-sided copying mode is automatically selected. When settings are selected that prevent 2-sided copying, the pamphlet copy function cannot be used.Comment
I would also suggest going into the print driver and making sure the copier is configured correctly if it is a print job. Check Sharp website, and make sure the FINISHER firmware and machine firmware is current. I emphasize finisher due to the fact that sometimes they release finisher firmware and don't put it on the machine firmware until the next machine firmware release.The Moose is loose!!Comment
I would also suggest going into the print driver and making sure the copier is configured correctly if it is a print job. Check Sharp website, and make sure the FINISHER firmware and machine firmware is current. I emphasize finisher due to the fact that sometimes they release finisher firmware and don't put it on the machine firmware until the next machine firmware release.Comment
I know it would be a pain, but if you've got a working FN-10 at the shop, then I'd bring it out and hook it up and see what happens.
At least you could isolate the problem to either the finisher or the main box.
If the problem points to the main unit, maybe it's a corrupted SD card???Comment
I had an MX-5111 with an FN-10 that wouldn't feed to the saddle tray and I discovered that I couldn't move the saddle staple units in the SIM mode. After trying the usual stuff... firmware, connectors reseated and settings on the unit, I ended up replacing the saddle stitch assembly and my problem was resolved. The removal of the saddle stitch unit is a 2 hour job if its your first time , just follow the manual and have some room to work if possible. This might not be your case but good luck either way.Comment
