MX 2300 Error - Please see system administrator. Error:PC
  • SLAMISguy
    • 12
    I am getting this message on boot up. Firmware is upgraded to latest version. Any ideas?
    Thanks in advance.
  • ZOOTECH
    Senior member of CRS
    • 3375
    That is a "Personal Counter" error that can be corrected in TC 26-3. If you have an external auditor, it might not be connected. Default (P10) is for the built-in auditor.
    • SLAMISguy
      • 12
      I have set it to default, but the error message remains.
      • ZOOTECH
        • 3375
        Check your connections at the SCN-Cnt pwb, especially CN131. This is the connector that an external auditor would plug into. Maybe a loose connection or a bent pin might be causing the machine to think it has an unplugged auditor.
        • SLAMISguy
          • 12
          Thanks ZT. Checked all of the connectors but still the same result. Thanks for your efforts.
