Rendering on Sharp MX-C311
  • MattL
    • Apr 2012
    • 97
    #16
    Re: Rendering on Sharp MX-C311
    We had a massive issue with rendering on the MX-5140 type machines, had a few firmware fixes that improved things. If you look in the spool on the copier all jobs render as the process some just take hours (tried and tested), I've got a document that I can use to make it render ever time regardless. Found a combination of firmware and drivers improved it, still get the odd one here and again, oddly if the file is saved from say a word document to PDF it is fine but word not. Make of that what you want!
