MX 4070 No Display
  • moose55
    • Mar 2017
    • 143
    [Electrical] MX 4070 No Display
    I recently had to remove the transfer lift clutch off our MX 4070 on the demo floor for another machine. Once I have put the demo machine back together I have no display panel? I have checked, and double checked ALL connectors. The panel power button comes on along with the home button, but no display panel. I did replace the wire harness from the SCU PWB to the control panel with no luck. I do not believe there are SD cards that would cause this are there?
    The Moose is loose!!
  • Paulm
    • 69
    Re: MX 4070 No Display
    Instead of SD they have mSATA drive. Had to replace 2 so far on these units. If you have a spare unit try it first. Then clone with HDD Raw Copy and re-image the original mSATA from the unit.
    • moose55
      • Mar 2017
      • 143
      Knew there was something besides an SD card! I will give that a try. Thanks!
      • moose55
        • Mar 2017
        • 143
        Unfortunately not the mSATA card?
        • mansart
          • 855
          Put machine in Emergency Firmware mode with dip switch on MFP board..... turn machine on and see is panel comes up.
          Check two bulletins below, they may assist in troubleshooting your problem
          TT-012317_2.PDF
          TT-051816_1R1.PDF
          • mojorolla
            The Wolf
            • 2630
            Two known issues for this model:
            1. the FFC harness, (flat, white and prone to failing) are known to fail. This runs from the SCN-MFP board, under the scanner to the op panel. Scanner has to be removed to replace, a whole lotta fun!
            2. Check the LVDS harness under the op panel. This is a known issue and have had at least 3 that back out of the harness when the machine is moved. Sharp created a new part for this one.
            If you know the IP and how to use VNC, you can remote into the machine to pull error codes and to SIM tests in service mode.
            • lgwilkinson
              • Nov 2016
              • 13
              had the same problem and it was the LVDS PWB part Number CPWBX2187FCE1. It is located under the display by the walk up sensor.
              • sharpie
                • Feb 2011
                • 184
                I have a MX3050 that had a low voltage "brownout" on supply and we are still trying to get the display up. The LED above the display panel should blink off for 2 seconds then on, off for 2 seconds for 4 sequences then become steady on state. This occurs while the boot process is taking place and my unit never comes out of the on/off blinking state. We have replaced the PCU, MFP/SCN bd, mSATA and Flash ROM. All voltages are present from DCPS. There is no EMUPDATE on this engine, we have to have a display to update firmware. Has anyone successfully brought one back from the dead?
                • austonrush
                  Sharp & HP Tech
                  • 242
                  Sharpie, I feel your pain, I've had the exact same thing occur. I never did bring mine back to life.
                  Moose55, did you solve the problem?
                  • MHeon71
                    • 489
                    A fellow tech had to replace the MFP PWB on 3 machines, but that was at setup.
                    • Craigcul
                      • Aug 2017
                      • 70
                      Have you tryed the sd card or ssd card as it sounds like the booting is not completing properly.
                      Sent from my Samsung A5 using Tapatalk
                      • moose55
                        • Mar 2017
                        • 143
                        I have tried the mSATA (this is in place of an SD card), LVDS PWB, SCU PWB, wire harness (from SCU PWB to display panel) and different display with no luck yet.
                        • Craigcul
                          • Aug 2017
                          • 70
                          Hi i have just found this technical report about the lcd connector changed is this possibleCCE1729.pdf
                          • moose55
                            • Mar 2017
                            • 143
                            Hi i have just found this technical report about the lcd connector changed is this possible[ATTACH]37617[/ATTACH]
                            Been replaced...but thanks anyway!
                            • moose55
                              • Mar 2017
                              • 143
                              Finally after all this time I have found the problem! It was a bad display screen wire harness (connector). It is the cable that goes into CN3 on the LVDS PWB. In a nutshell it ends up me over thinking a problem! Thank you all for the input and advice!
