MX-3610 calibration fail
  • mattwill1107
    • Aug 2008
    • 26
    I have an MX-3610 that, when you go into SIM 46-74 calibration, and hit the execute button, the machine starts to act like it's starting the process, then double beeps, and the highlight on the execute button goes off without printing the test page. This also happens when trying to perform a user calibration through systems settings, and doing the calibrations for copy and print separately (46-24 and 67-24). We've tried with 8 1/2 x 11 paper in all 3 drawers, and also 11 x 17. Any thoughts from anyone?
  • driving lots of miles
    • Jun 2016
    • 403
    Re: MX-3610 calibration fail
    Have you tried running sim 50-22 first and after making any corrections there then running 46-74?
    • mojorolla
      The Wolf
      • 2630
      Set all four drawers to the same paper size and orientation. I have seen this on the Polaris (6240,7040) machines also.
      Also, 46-74 will not run if using other SIMS first. Exit SIM mode, enter SIM mode and immediately do 46-74.
      • mattwill1107
        • Aug 2008
        • 26
        Thanks for the replies. I did do a 50-22 because I had just replaced the primary transfer belt and blade on the same call. We did have all 3 drawers on the machine set for 8 1/2 x 11, and got a failure. Can't say with certainty about the SIMS, so that is something I can check out.
        • ZOOTECH
          Senior member of CRS
          • 3376
          Most likely, I'm mistaken, but shouldn't the paper size be either 8.5x11R, or 11x17?
          • r3d343420
            • Aug 2012
            • 56
            may sound dumb but, are the paper trays all set to plain paper?
            • mojorolla
              The Wolf
              • 2630
              A 2610 does not have auto size sensing in tray 1, it must be entered manually. By default, SIM setups come from tray 1.
              • Jkearbey
                • Nov 2016
                • 15
                This sounds very similar to an issue I had last month??? How do your internal color test prints look? 64-5 , etc. Will it even print that ? It should since its not a calibration SIM but a test pattern . In my case when I ran the 46-74 the machine would print out the chart but when I went to scan it off the glass that is when it would beep and fail to scan. My color prints didn't look that great and then I started getting an intermittent laser error code. I replaced the LSU and problem went away. Calibration started working again and all is well. Good luck.
                • Craigcul
                  • Aug 2017
                  • 70
                  Hi there have you tryed running crop 44-06 proccess control if this fails clean you process control sensors.
                  Sent from my SM-A520F using Tapatalk
