MX3610 Calibration fault
  • woko
    • Jun 2017
    • 44
    [Misc] MX3610 Calibration fault
    Hello All, I have a MX3610 that won't calibrate SC 64/74 I put the print on the glass the machine scans then just says put the chart on the glass? machine copies fine and prints ok however the colours are not right as it won't calibrate.
    any ideas??
    all the best Woko
  • dwarf
    • Oct 2012
    • 168
    Re: MX3610 Calibration fault
    SC 46-74...if the machine scans but won't produce the next page for calibration, I believe you have placed the copy down incorrectly on the platen..the little black orientation line must be all the way to the left...
    • JLSam
      • Jun 2015
      • 605
      Second Dwarfs comment.
      • woko
        • Jun 2017
        • 44
        thanks I know about that and what ever way you have the sheet it won't calibrate
        • dwarf
          • Oct 2012
          • 168
          lots to consider...try firmware...not sure if a sim card is in it...use several sheets to back up the test sheet...or you may have a bad board...
          • woko
            • Jun 2017
            • 44
            I have now been able to reset the calibration setting to factory default with sc 67/31 so the copy quality is no OK, will post if I find out what's caused this problem.
            Woko
            • austonrush
              Sharp & HP Tech
              • 234
              Try Sim 50-28 first
              First run BK-MAG Adjust and then run SETUP/PRINT Adjust, restart and try again. The issue is the copier sees the chart but, it cannot read it as your out of calibration.
              This will almost always solve this specific problem.
              As to your colour requirements you can also try changing SIM 63-11 to def 1 from def 2. You must calibrate after you make any adjustments here.
              cheers
                you did clean the optics before trying the calibration correct? I have seen techs waste time on trying to calibrate with out cleaning the optics first.
                • woko
                  • Jun 2017
                  • 44
                  Originally posted by Brandon55
                  Try Sim 50-28 first
                  cheers
                  Thanks I will try this and let you know, the machine is a stock machine that's in my workshop so I will drag it out and see
                  • austonrush
                    Sharp & HP Tech
                    • 234
                    Great, let us know if it works!
                    • miv1
                      • Apr 2016
                      • 2
                      Check to confirm that the image density sensor calibration plate
                      is clean.
