MX-5111n, L4-11 with binding paper exit mechanism, osm motor and Pcu pwb are fine
  • jeffrodh
    • Aug 2017
    • 21
    [Misc] MX-5111n, L4-11 with binding paper exit mechanism, osm motor and Pcu pwb are fine
    Hello and good morning. I'm working on Sharps for the first time and really struggling. I'm getting an L4-11 code with a tested good PCU PWB and tested good OSM motor. The motor runs when I run a 6-1, the SHPOS sensor is reporting as expected. The winding resistance is equal in all 4 phases, and the mechanism rotates freely when out of the machine. No broken teeth on the gears, etc.
    However, as soon as I insert the bloody thing (paper exit assembly) in fully, the shifter motor mechanism binds up completely, and appears to be getting hung on a part of the case toward the output side.
    I've worked on this problem for a few days, and tried to post on here last week, but apparently something went wrong because I don't see my post.
    I'm utterly flummoxed. I can still scan and fax if I power up the machine with the right side open, but that's hardly satisfactory.
    Thanks in advance for sharing your experience!
    Last edited by jeffrodh; 08-28-2017, 06:52 PM. Reason: Problem solved with help, changing title to reflect
  • spanky
    • Sep 2012
    • 468
    Re: MX-5111n, L4-11 with binding paper exit mechanism, osm motor and Pcu pwb are fin
    Remove the exit unit from the machine and remove the drive motor.
    Try moving the shifter and see if you have a mechanical binding when moving it.
    • jeffrodh
      • Aug 2017
      • 21
      I have done so. It moves freely outside of the machine. It moves without binding with the motor installed as well, but I can feel the resistance of the permanent magnet motor.
      There looks to be a small teflon piece near the rear that the slide is fitting into, but it prevents all movement. I'll try to upload some images. It continues to move freely until I fully seat the paper exit mechanism (the last 3-4 mm is where it begins to bind).
      • jeffrodh
        • Aug 2017
        • 21
        • ZOOTECH
          Senior member of CRS
          • 3376
          Originally posted by jeffrodh
          [ATTACH=CONFIG]37455[/ATTACH][ATTACH=CONFIG]37456[/ATTACH]
          That looks like part of the pass through for the finisher is still installed.
          • mttech
            • Mar 2014
            • 127
            Did this machine have a finisher previously attached to it? That looks like you still have the fixing plate attached. Remove the plate in the second photo, 1 screw towards front of copier, then power cycle.
            • jeffrodh
              • Aug 2017
              • 21
              I'm going to be a little dense here. You're going to have to help me out, as it's been several years since I've done this as my day job, and it's my first time working on a Sharp, although I do have the Service Manual, it's woefully inadequate in a lot of ways without other sources of information/experience.
              I've considered removing that teflon piece and the silver bar next to it, as that's the thing I think is causing the problem. I can't fathom why/how the copier has worked for the past several months with those pieces installed without error. We've got a finisher (the piece after the paper exit mechanism, I assume) that has a stapler... I can take another picture if necessary.
              Thanks again.
              EDIT:
              • jeffrodh
                • Aug 2017
                • 21
                Using my context clues, lol, it seems like the copier has been recognizing a finisher and disabling the OSM, but recently began to think that no finisher was installed and the fixer plate is causing problems?
                Is my reasoning sound?
                • harleyrider
                  • Oct 2011
                  • 348
                  check your install guide for the finisher. the nylon piece locks the shifter from moving.
                  • jeffrodh
                    • Aug 2017
                    • 21
                    Holy balls. Checked the wiring harness for the finisher after reviewing the finisher install guide per the above suggestion, and it was knocked loose. Lol.
                    Well, I scored with an ID10T error here. Spent 5 days sourcing a stepper motor ($9.50 vs. the $115 part from precisionroller), testing the motor, testing the PCU PWB, and beating my head up against the wall and it was a bloody plug. A BLOODY PLUG, I SAY!
                    Thank you all for your insight and for sharing your experience. I know a whole lot more about this machine than I did a week ago. Now if I can just get Spectrum out here to fix the cracked signal line for the internet, we'll be in good shape.
                    [SOLVED]
                      welcome to our world... always " measure twice ..cut once" an old carpenters saying.. meaning check your work
                      • jeffrodh
                        • Aug 2017
                        • 21
                        No doubt. In this case I was just too ignorant of the different components to know to even check the finisher. But thanks to the community pointing me in the right direction....
