MX-B401 Code E7-11
  • KMtech69
    • 68
    MX-B401 Code E7-11
    Hi All,
    I'm working on a sharp MX-B401 that has a code E7-11 that is intermittent. I have reseated all connectors on the scanner board and scanner unit. I also cleaned the optics, glass and the reference plate. Any help would be great.
    Thank you in advanced.
  • Ratchet2501
    • Mar 2017
    • 206
    Re: MX-B401 Code E7-11
    How does the LSU unit look/work? I've got a b402 I'm waiting on parts for that I believe had the same error due to the motor going bad.
    • moose55
      • Mar 2017
      • 143
      Originally posted by KMtech69
      Hi All,
      I would say that your next step would be to replace the SCU PWB. Make sure the wire harnesses are in good shape (up to the scanner).
      The Moose is loose!!
      • mojorolla
        The Wolf
        • 2609
        B401 are notorious for the white reference strip under the platen discoloring. Over time, the glue turns the white strip yellow, causing E7-11.
