F2-64 MX-M503n
  • Sharptech56
    • Feb 2016
    • 100
    [Error Code] F2-64 MX-M503n
    Hello all,
    I have a MX-M503n with 300K on it and it staryed clicking , saying "toner replenishment" and eventually F2-64 already tried new toner . Ordering toner clutch am I missing something ?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: F2-64 MX-M503n
    Originally posted by Sharptech56
    Hello all,
    There was quite a few models that sat on the docks after a longshoreman strike or Japan's tusnami, and the toner add clutch had rusted - it usually had shown up during setup, but after 300k would not be unusual.
    Cheat the front door, remove the toner cartridge, and run 25-01; check the toner drive gear, and see if it is moving, replace if it is moving.
    Also, check that the entire toner seal was removed during install.
    • mttech
      • Mar 2014
      • 127
      Re: F2-64 MX-M503n
      I did have one recently that had the toner chute on DV unit plugged. Not sure how this happened, but it did. Cleared chute and off to the races. When checking toner drive gear as Zootech stated inspect this also.
      • tee
        • Aug 2014
        • 79
        Re: F2-64 MX-M503n
        I would turn on dv check disable in
        simulation 7-1. Then check for a ready position.
        Run a copy and check if dv unit or toner is bad.
        • techwurk
          • 127
          Re: F2-64 MX-M503n
          Clicking noise could be a seized developing unit. I just had this issue and it was a seized unit, but that 503 has 2.4 million pages on it.
          When I started servicing copiers they used toaster ovens for fusers.....I'm old
          • Sharptech56
            • Feb 2016
            • 100
            Re: F2-64 MX-M503n
            All good suggestions guess I got some work to do I will post what I find............
            • mojorolla
              The Wolf
              • 2627
              Re: F2-64 MX-M503n
              F2-64 simply means toner is not making it to the DV unit. It has been my experience that clicking is usually from the toner cart spinning. As stated earlier, you may have a clogged toner tube, I have seen a few of the referenced rusted clutches. You could also have no drive on the DV unit.
              Go into SIM 25-1 and execute for 10 seconds. If the DV unit is not getting toner, the number will be very high, like 170 or above.
              • Sharptech56
                • Feb 2016
                • 100
                Re: F2-64 MX-M503n
                Finally got back to account checked DV unit toner chute and cleaned toner clutch . I then checked the toner itself and found it did not really turn well by hand
                so I must of shooked,banged,and turned the augers for 5 minutes and ran 50 copies . We will see if it comes back...
                • austonrush
                  Sharp & HP Tech
                  • 234
                  Re: F2-64 MX-M503n
                  I'd suggest looking at the developer motor itself. I've had a couple fail over the years. A quick way to check is to pull the developer unit out and inspect where the toner feeds in to the unit itself. If the toner is super packed in there then that is a sign the developer unit is not rotating. Toner is feeding down into the unit but has nowhere to go so it just compacts itself.
                  Your failure, most likely, lies with one of these three things
                  Blocked Toner Pipe
                  Seized developer unit (you can clean this and temporarily resolve the problem but, it will most likely come back if worn)
                  Broken developer drive motor
                  After I wrote this I saw you just responded... lol
