MX-2610 E7-A0
  • niceville318
    • Feb 2014
    • 43
    [Error Code] MX-2610 E7-A0
    I have a Sharp MX-2610 that has intermittent E7-A0 codes. I've already replaced the LSU with driver PWB and just replaced the LSU motherboard from a spare MX-3110 (same Part#). Within 5 minutes it popped another E7-A0. I can reset using sim 14 and it may take a few days of several weeks for it to come up again, its occurred 7 times between 4/2017 and 9/2017. Other than the harness, any suggestions?
  • Exper3
    • Jun 2015
    • 4
    Re: MX-2610 E7-A0
    what error codes does it give?
    E7 48 Scanner expansion PWB (ACRE) ASIC memory error
    42 Image data trouble (Scanner expansion PWB (ACRE) ASIC)
    96 MFPC PWB DIMM memory check error (MFPC PWB)
    95 Printer PWB DIMM memory check error (PRINTER section)
    A0 04 Scanner expansion PWB (ACU) (ACRE) ROM error
    • niceville318
      • Feb 2014
      • 43
      Re: MX-2610 E7-A0
      I apologize if I didn't make it clear in my initial post but the code is:
      E7-A0 LSU LD PWB EEPROM read/write
      error (K)
      Trouble content Write error in the EEPROM write sequence
      Detail PCU
      Cause LD PWB EEPROM trouble.
      LSU mother PWB trouble.
      Connector/harness trouble between the LD PWB and
      the LSU mother PWB.
      Connector/harness trouble between the PCU PWB
      and the LSU mother PWB.
      Check & Remedy Check the LSU, and replace if necessary.
      Check the LSU mother PWB, and replace if
      necessary.
      Check the connector/harness between the LD PWB
      and the LSU mother PWB, and replace if necessary.
      Check the connector/harness between the PCU PWB
      Replace the LSU.
      • mojorolla
        The Wolf
        • 2596
        Re: MX-2610 E7-A0
        Print out the 22-6 and look at the soft switches. I have seen board replacement set all the soft switches to 1.
        This usually happens with Frontier scanner boards....
        • oeshuron
          • May 2008
          • 259
          Re: MX-2610 E7-A0
          Any chance this was resolved? Have a machine throwing this as well. Have replaced laser and pwb.
          • niceville318
            • Feb 2014
            • 43
            Re: MX-2610 E7-A0
            i apologize for not updating this thread, I replaced the LSU motherboard and have not had anymore occurrences of the code.
