MX-M354N
  • Ratchet2501
    • Mar 2017
    • 206
    MX-M354N
    Copies are tilted on this machine and I'm thinking 50-1 may be able to readjust it, might not. I've replaced the cleaning roller and fuser thus far since they were both up there.Prints are fine. At first I thought it was the adf that was the problem (crap in the gears etc) but even the flatbed is copying crooked.noreply@gmail.com_20170925_135635.pdf
  • ZOOTECH
    Senior member of CRS
    • 3376
    Re: MX-M354N
    Was that second page copied or the original print?
    After rechecking the .pdf, and with mansart's post, I agree that optics need adjusting. (Was it off the glass or through the doc feeder?)
    • mansart
      • 855
      Re: MX-M354N
      If the second image is a copy of the first......you have some work in optics........looks like mirror assembly has come out of adjust and/or one of the clips that secure the mirrors have come out.
      • Ratchet2501
        • Mar 2017
        • 206
        Re: MX-M354N
        Terrible thread authoring on my part, apologies. Yes the second page is the "copy" of the first from the flatbed. I'm only mildy scared to adjust the optics since outside of scrapping a machine I havent ever been in there. First time for everything I guess.
        • ZOOTECH
          • 3376
          Re: MX-M354N
          Hopefully, you have the service manual; just follow the steps, from the beginning, and you should be fine.
          • mojorolla
            The Wolf
            • 2630
            Re: MX-M354N
            According to the 22-6 tray 1 has almost 1/4 million clicks on the rolls. Verify that it happens from all trays before messing with optics. Make sure you are printing and copying from the same tray when trouble shooting. That is A LOT of skew for an optical issue usually.
            Check feed rolls and paper path as the paper is already skewed when the image is applied.
