AR 5625 spil developer
  • Gab
    • Aug 2015
    • 655
    When i chcked machine developer was dropped at paper cassete (i cleaned rollers to stop paper jam) and at transport roller area. I clened machine and drum unit. made some copies and developer was spiled over image. 0
    I inspecked developer unit and noticed developer have been over seal (the seal above mag roller). I Used adhesive tape instead this seal (till now it always worked) , i replaced developer (performed 25,2 ) and drum. Developer now doesn't overcome seal. I made some copies . The first 2 or 3 was ok but the rest had developer spiled at the center and in every copy increased. Any idea?
    Somebody answered to me that the problem is at charge corona . Can i use ar 5316 charge corona on 5625?
  • techwurk
    • 127
    Re: AR 5625 spil developer
    Yes, can be the main charge sawtooth and also aftermarket developers can cause it too.
    When I started servicing copiers they used toaster ovens for fusers.....I'm old
