Sharp MX-M 363 L4-32
  • techwurk
    • 127
    After resetting the code (L4-32 power source cooling fan) did not come back but doing a general service on the machine tomorrow and wondering if anyone else had this fan cause issue.
    When I started servicing copiers they used toaster ovens for fusers.....I'm old
  • austonrush
    Sharp & HP Tech
    • 234
    Re: Sharp MX-M 363 L4-32
    I'd replace the fan. No point having a call back. Your going anyways
    You can test through sim 6
    • mojorolla
      The Wolf
      • 2627
      I have seen this a few times, if it happened once, it is just a matter of time until it returns.
      Fans are cheap, replace it....
      • techwurk
        • 127
        Thanks for help, yes the fan has been replaced
        • dwarf
          • Oct 2012
          • 168
          even with brand new fans, I've seen the code return quickly... never did solve the problem
