this beast will fold over the paper after the reg roller, ? maybe at the transfer roller as there is an image placed after the copy paper has several fold creases where some image is missing due to this, and then crumples one side as its leaving the fuser. and they have it almost in a closet. i have removed the right side door/ transport mod and inspected the transfer roller. they said it started after label jammed, but i cant find any inside. there is a strange transport guide and roller just below registration roller that transitions from a horizontal to a vertical direction, but since i couldn't pull the drum and developer modules, (due to the machine space neglect) i couldn't get that guide out to check inside.
if anyone has run into this type of issue, i would really appreciate a suggestion. i am going back and will pull it out into the lobby if i can. thank you very much, Jim
